View IP VRRPv3 Statistics
Use the following procedure to view IPv6 VRRPv3 statistics for monitoring the network performance.
  1. In the navigation pane, expand Configuration > IP.
  2. Select VRRP.
  3. Select the V3 Stats tab.
V3 Stats Field Descriptions
Use the data in the following table to interpret the V3 Stats tab.
Name
Description
InetAddrType
Shows that the address type of the statistical entry is IPv4.
ChecksumErrors
Specifies the total number of VRRP packets received with an invalid VRRP checksum value.
VersionErrors
Specifies the total number of VRRP packets received with an unknown or unsupported version number.
VrIdErrors
Specifies the total number of VRRP packets received with an invalid VRID for the virtual router.
